Originally Posted by Stubby79
good reason to stick with the cooler line running through the radiator...well, assuming the radiator is ever up to temp, which it never is...
Ok, good reason to run the oil cooling lines through the hot side of the cooling system.
My racing radiator has no trans oil cooler. And even if it did I don't know how much heat it would actually add to the fluid being on the cold side of the rad. Probably not much, it may even cool the fluid in the winter when the thermostat isn't open much or at all.
