Old 07-17-2019, 02:42 PM   #13 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by EcoCivic View Post
Thanks. So you are saying that running this cold may actually be harmful to the transmission?
reiterate: No probably not. I don't actually know what the spec for ATF would be in your application, but you will lose a couple percent in FE since you're a couple degrees colder than optimal.
I would just plug your lines, and run a test loop with and without and see what the difference was. I used to have a 5 mile test loop I used on the mustang.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
EcoCivic (07-17-2019)
