Old 07-18-2019, 12:15 PM   #255 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
I did the under seat sub with the DB652's, it helps a lot. I got the 10" Rockville... I'd get the 8" if I was doing it again.
It helps a lot with the bass, but you need to set your crossover fairly high because the DB652's are falling off in their output at a shockingly high frequency.
The Following User Says Thank You to samwichse For This Useful Post:
mpg_numbers_guy (07-18-2019)
