Old 07-18-2019, 07:47 PM   #256 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Something I found about solar panels under the glass in the back, was that output was significantly lower - the glass blocks a fair amount of solar energy. Plus the sun has to be at a very good angle (almost directly overhead) to get any significant output.
Maybe in the car when driving and outside the car when parked? As seen though on today's response on the IC thread, with my hypermiling I wouldn't see much FE benefit from such a setup.
Originally Posted by samwichse View Post
I did the under seat sub with the DB652's, it helps a lot. I got the 10" Rockville... I'd get the 8" if I was doing it again.
It helps a lot with the bass, but you need to set your crossover fairly high because the DB652's are falling off in their output at a shockingly high frequency.
Is that because the 10" has too much bass for your liking, or because of size? How much clearance is there between the sub and the bottom of the seat?
I'll keep that in mind, thanks for the info, and yes I have noticed that with the DB652s - the base seems less than stock but better quality.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
