Old 07-20-2019, 01:59 PM   #16 (permalink)
woodstock74
TBD - '17 Toyota Corolla LE
Last 3: 36.26 mpg (US)
Starship - '08 Toyota Prius
90 day: 45.82 mpg (US)
Starship Resurrected - '08 Toyota Prius
Could the opening simply be for adequate brake cooling during a panic stop?
Perhaps? One Aero here at work indicated that might be the case; brake cooling. The region ahead of the spat is a concavity and I've templated a small plate that covers over it providing a much smoother path to that spat. Probably will do nothing, but it bugged me on principle. Furthermore, I spent $47 and purchased the LE Eco front underfloor "splash panel" that smooths out the front center underfloor section (I'll post images later on), so these outboard panels ahead of the spat simply complement those.
The Following User Says Thank You to woodstock74 For This Useful Post:
aerohead (07-20-2019)
