Originally Posted by MetroMPG
No doubt there are better tires out there now.
The trouble is selection in Canada / US is almost non-existant in the original size. The only car left on the market which uses the original size is the Mirage (Space Star). It's one of the last (if not the only) new cars with 14" wheels.
What's the bolt pattern and offset? Cheap steel wheels should be easy to find in other diameters. So long as you know the specs to look for you can match them with other make/model vehicles. People mostly take off steelies and put on alloys so the steelies should be plentiful.
