Old 07-23-2019, 08:58 AM   #62 (permalink)
Snax
Lord Vader - '15 BMW i3 REx
90 day: 35.06 mpg (US)
Here's my disc mounting system using sprinkler hose and stainless screws around the perimeter. The hose ring is rigid enough to stay in place on it's own, but cut a few mm too large is stuffed tightly into the recess.
Originally Posted by Vman455 View Post
I can't find data for the 20", but this Jalopnik article reports BMW said the 19" would be 15 lbs before production started. With the tire weights listed at tirerack.com, that would make 31 lbs front/33 lbs rear.
Just short of 36 lbs is what I got for the front wheel. Safe to bet on 38 for the rear. Could be lighter, but not much. I suspect that dropping to the 19" wheels would carry a Crr penalty though, more than cancelling out any weight reduction.
ID:	26483   Click image for larger version
2015 BMW i3 REx
2011 Ford Flex SEL AWD
