07-23-2019, 03:29 PM
#18 (permalink)
All cryogenic should do is stress relief without softening...
I've provided sources. This is a good one: thefabricator.com:Cryogenic processing—dispelling the myths, mysteries
Cooling your tooling for improved wear resistance, compressive strength
Figure 1: The leftmost diagram illustrates a theoretical cubic structure. Two cubic steel structures are body-centered cubic (BCC), also known as ferrite (second from left), and face-centered cubic (FCC), which is austenite (third from left). The face-centered tetragonal (FCT) structure, far right, is known as martensite. The FCT structure is about 14 percent larger than the FCC structure.
It involves excursions above and below room temperature.
