Old 07-24-2019, 10:48 AM   #71 (permalink)
aerohead
F/R
Originally Posted by mpg_numbers_guy View Post
You will likely notice more of a benefit with rear wheel covers than front wheel covers. I removed the front wheel covers from my Civic when I had it and left the rear ones installed, and didn't notice and discernible fuel economy loss. My theory is that rear wheel covers have a larger effect since they're near the rear of the car, and any flow disruption near the rear of the car will add more drag.
Some observations have indicated a greater drag reduction from the front skirts. I know this to be true for a 1930s Adler coupe and the 1983 Ford Probe-IV.(9% in the case of the Ford).
I do agree that if the fronts are done,then you've got the best onset flow available to the rear of the car,which amplifies the ability of the rear skirt,hence pressure drag advantage.
Snax (07-24-2019)
