Originally Posted by MetroMPG
Am I right in reading in your Prius thread that the Camry's battery isn't happy?
Yep, Prius battery took a poop a couple weeks ago followed closely by the Camry throwing a code. I swapped the good modules from the Camry into the Prius so I could get the Prius to pass emissions and to have a working car.
I'm considering rebuilding the Camry's battery with
these new modules and then piecing together a functioning pack for the Prius using the stock modules from the two cars. It doesn't make a ton of sense to drop ~$2k into a car with 205k miles, but I figure if anything happens to the Camry, I can just swap the new modules into the Prius or pick up a Camry with a dead battery. I would be a few modules short if I did it the other way around and got the new modules for the Prius and then had to put them in the Camry.
