Old 07-24-2019, 07:15 PM   #48 (permalink)
EcoCivic
Originally Posted by litesong View Post
I find the 2016 manual transmission shows greater power at all throttle positions AND all rpm ranges, than the 2013 automatic transmission. Just thought of something else, because of your question. Do both car engines, rev with equal verve, BEFORE the transmissions are engaged? Would you have any interest in such an experiment? I'll have to test both cars to make a comparative determination. If you don't have an interest, I won't conduct the experiment.
I think that would be a great test! It would show the differences (if any) in the rate the engine revs at, probably mostly due to the weight of the flywheel and clutch compared to the (likely heavier) torque converter. If you want to, another interesting thing to test would be what the difference is with the clutch in or out on the manual trans. Just make sure both engines are fully warmed up before you test this obviously.
