Old 09-10-2008, 11:56 AM   #69 (permalink)
jdub
jdub's Avatar
TDI Cup - '10 Volkswagen Jetta TDI Cup Street
90 day: 50.3 mpg (US)
I believe the answer lies in the Peltier Effect
Thermoelectric couplers (or peltiers as they are sometimes called) use the Peltier Effect to heat pump (by consuming a small amount of electricity) temperature from one place to another. The great thing about peltiers is that depending on the orientation of the voltage, they can cool AND heat within the same setup.
peltier based personal refrigerators have been around for several years, and there are several patents for using peltiers as a "personal heating and cooling" solution. Several new luxury cars are also coming with these units as options.
I believe this is where the solution to the problem lies. The portable peltier based refrigerator that I have runs off 12v, consumes a nominal amount of wattage such that it can be used via an accessory plug and gets the internal temperature down into the 30s when switched into cooling mode.
Perhaps a seat cover containing 2 large peltiers with the leads connected to an accessory plug (with a switch to change from heating to cooling) would possibly be an ideal personal cooling solution for this.
While this will not cool the entire cabin temperature, most of the heat and sweat you produce when inside a car occurs along the contact point of the seat. Turning that contact point into a cooling plate will help you feel cool even if the cabin temperature is in the 80-90s (which can even be accomplished on the hottest days by ventilating the cabin as soon as you get in by driving the first few miles with the windows open.
Seems like the perfect solution to me. I saw a story in one of the street rod magazines a few years back about a kit for rods to do this because they are most times very cramped in terms of retrofitting an under dash unit. I have spent some time looking to dig up that tech article but have not had luck yet. I believe it was either Street Rodder or Rod and Custom...
Anyway, I will keep looking but I wanted to mention this so others could investigate/evaluate as well since it provides all seasons comfort for nominal electrical consumption.
