Originally Posted by Vman455
It looks like the 2011 Volt has belly pans, but no engine undertray? Is that correct?
FWIW, the 2nd generation Volt had an engine undertray, a full airdam, and separate wheel strakes:
Yup! The mid section is pretty flat however the engine compartment could use a lot of work in the aero department! Should not be too hard to make a flat floor as there are a few bolts already built into the support beams which one could fasten a piece of coroplast. The rear is also a very odd shape but I imagine Chevy probably designed it that way on purpose. I tried messing with the rear however I had no luck as there are not really many great places to mount a board.
