Originally Posted by jdub
Thermoelectric couplers (or peltiers as they are sometimes called) use the Peltier Effect to heat pump (by consuming a small amount of electricity) temperature from one place to another.
One mistake in that, which makes the concept unworkable. The Peltier junction uses a LARGE amount of electricity relative to the amount of cooling produced. The standard car A/C would use much less power - and you could run some plumbing to duct cool air to the seats.
