Old 07-29-2019, 10:46 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
fwiw, the ac clutch coil is like 2 to 5 ohms, like a 50 watt load. might not be a big deal if it solves more problems than it creates.
scanning this, it looks like you can expect very roughly about 80 foot/lbs from an automotive ac clutch.
https://www.warnerelectric.com/-/med...p-1091-we.ashx
in perspective, you could put one on the output shaft of a ninja 250, and if you never used first gear you might get away with it.
they make larger magnetic clutches though, in some AWD, or a larger vehicle in need of AC.
