edit: I think probably the "grind the detent cam" so you have a half click neutral between all the gears approach would be a lot easier to implement, if you know where/how to grind.
keep in mind that most motorcycle trannys aren't properly lubricated for lots of miles unless the engine is running (or you have made other provisions).
