Originally Posted by woodstock74
So, if you have in the region of $100,000, you might have something to do with your 1/32 scale models!
I'm thinking cost is less of an issue than potential inaccuracy of the design. Very small changes make a huge difference there, but that may be less important than overall generalized effect - even if it does not end up accurate in real world use. If nothing else, something for my teenager to lean on for a science project at some point perhaps . .
I did score a nice recycling yard find today however of a 4x8 1/8" sheet of black plastic. Not sure it's ABS, as it seems more flexible than that, but it seems a good mix of rigidity and flexibility to conform to simple curves and mild complex ones.
At the very least, I think it would be a decent upgrade for my wheel discs in being solid and less susceptible to cosmetic damage, along with being thinner than the 4 mm stuff I have now. It should work well around the lower suspension arms too.
