Old 07-31-2019, 03:35 PM   #58 (permalink)
redpoint5
90 day: 43.3 mpg (US)
Depreciation is nearly always the biggest cost. The newer the vehicle, the bigger a hit you're going to take. "Fuel" cost is usually not as big of a concern as depreciation.
You seem to be implying that PHEVs cycle the battery between 0-100%, but I want to clarify that they don't. They are very conservative. For instance, my Prius operates between about 25-85%. In other words, a full charge is only 85% SoC, and empty (engine kicks on) is about 25%.
The vehicle cost of ownership calculator linked in my signature can compare any 2 vehicles, including PHEVs. You'll have to estimate the percent of EV miles you anticipate for a PHEV (it's one of the data fields), but it's as accurate as the assumptions you input. It will break out the various costs, such as depreciation and fuel cost.
