Originally Posted by hayden55
https://www.amazon.com/Xiaomi-Electr...gateway&sr=8-2
One of these would be the best bet. I noticed on an engineering document a while ago it said they were only using 1900 mAh 18650 cells for their battery pack. If you swapped to 3500 mAh cells you could really increase the range and speed on one of these with a new motor controller and a temp sensor. It would be a cool project to work on, but my city isn't urban enough for something like this. They aren't super light weight either. Maybe with the more energy dense batteries in series and parallel you could shrink the pack size and swiss cheese the frame a little lol.
I've had one up to 20 mph here down hill (bird scooter), but the electric scooter law is 28 mph and below. Would be a wild ride at 28 lol.
The higher end scooters here can do up to and beyond 80 km/h (about 50 mph).
Which is vastly more than you need for an in-city commute. 30-40 mph would be more than enough.
The problem is, to build up a kick scooter to withstand those speeds, you need to add bigger tires and an actual suspension (unless you like breaking the front arms off when you hit something at speed), and those things become much less portable.
