Thread: 0W-16 is here!
Old 08-01-2019, 04:55 PM   #26 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Wouldn't the best but gutsy idea, use the 0-16 when the motor is new, then switch to 0-20 as it ages, and finally even something thicker when it is really old and tolerances have opened up. This one size oil recommendation for life of the motor from 0 miles to 300,000 miles seems simplified for the masses.
That would be a correct assumption, but we all know Toyota's engines don't actually wear. They are just thrown away after one too many accidents with the DVDO they experience.
On the subject I'm about to hit 10k on 0w-16 while towing a 1000lb quite a bit. How much y'all wanna see the results?
Also the car has 150k
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
