Old 08-04-2019, 11:15 AM   #1 (permalink)
sardonicus
Modding my 1979 Ford F150 - looking for some opinions
So I have recently started working on my truck, progress is slow because funding is limited and I work on a poultry farm my family owns and am coming up on that time of flock where I'll be without pay for a couple months so this is mostly just an information gathering exercise.
There are several things I want to do with this truck, but one thing I wont be doing is a total electric conversion. I like working with the gasoline engines so it'll be staying, but I do want to improve fuel economy while having a little fun experimenting with some things.
The first thing I want to do is add hydrogen, and lots of it. Being that this is an older vehicle there is oodles of space for me to work with and in the end I will likely be running multiple hho generators - to start with though one will have to do and I'll go from there. The engine in my truck is a carbureted 302 with a 2 barrel carburetor. If anyone has experience with hho and these engines I would be curious to know how thats worked out for you. How much hho have you been able to pump into it before detonation became a problem? Any suggestions on this line of modification are welcome.
The next thing I want to do is to add an electric assist motor - this is where things get tricky for me as I've never done anything like this before, but here is my plan. My truck is two wheel drive but I know that they made them 4 wheel drive I am on the hunt for a front differential that will bolt up to my truck - preferably with no or little modification to the frame and supports. Then I want to run a drive shaft from that differential directly to a motor - wherever I can weld up a mount for a motor. With all the space available under there I dont think that will be a problem. I am looking for motor suggestions here because I really dont know where to start. I definitely want regenerative braking so if my understanding of things is correct I will need an AC motor. My hope is that by supplying power to the front wheels via an electric motor it will be easier for the gas engine to supply power to the rear wheels and overall make things more efficient. Motor, controller, inverter advice is all welcome here as well anyone with thoughts on how effective my plan really will be. I'm open to any better ideas too.
On the more experimental side of things I intend to attempt to reclaim some of the wasted heat energy from the gas engine. They waste so much in the form of heat and I believe that I can harness some of that waste by using banks of thermoelectric generators. The challenge I think will be finding a way to keep the cool side cool enough for usable electricity generation to occur. If anyones dabbled with something like this I'd be curious to know what kind of results they had.
