Originally Posted by Binger
so let me get this straight dremd...water goes through the solar heater and into the bosch unit...but because its already heated your bosch just maintains a steady temp...thus using less propane because it knows the waters already heated? correct?
98% correct; the only difference is I have switched from propane over to Electric.
Some days the bosch doesn't even switch on, somedays it does some work, and sometimes it is darn near the only source of heat.
