Old 08-09-2019, 02:10 AM   #21 (permalink)
dwtaylorpdx
FWIW,, ATF is usually viscosity stable in a pretty wide range,,
In a tow vehicle they usually recommend keeping the auto under
220. few auto lubricants like to be any hotter.
I believe the redline website used to have a table for proper temps,,
Redline ATF, with no cooler lowers my transfercase temp about 40 degrees on my jeep when in low range working it hard.
I think its as important to keep the temp consistent as it is to keep it low.
Thermal changes work the parts harder..
If it has a motor its worth playing with.......
The Following User Says Thank You to dwtaylorpdx For This Useful Post:
EcoCivic (08-09-2019)
