Originally Posted by Xist
Considering she spent $339 the other day to have a plumber replace her back faucet after I looked up instructions, but needed to leave for work, I am prepared for frustration.
She did not have him look at her kitchen faucet, which I fixed for $4.
I mean if that tire is worn out I would just replace it. Pump it up to 35 pounds, and then drive to a different tire shop, as the one you are at is clearly run by incompetent buffoons.
If the low tire still has good tread, then find the leak the way I described, plug the hole, and move on with life. Take a good little drive after plugging the hole, as getting the tire hot helps the plug adhere.
