Old 08-10-2019, 10:17 PM   #281 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
I considered doing the very same thing. My Mean Well was nearly silent with my dual 90mm fan setup but it was interesting to me that the turn signals alone could rev the fans up more than just about anything else in the car. Really puts in perspective how much energy they use.
Ultimately I didn't, because they're on for such little time.
If it was just a revving fan it would be no issue, but when I'm cruising at 800-900 RPM with the Meanwell just barely supporting base load, turning the turn signals on turns the meanwell off due to too much load for how low the input voltage is at those low RPMs. Then I have to be at 1200+ RPM for ~5 seconds for it to turn back on.
Originally Posted by 19bonestock88 View Post
Lucky you, I’ve no way to correct my hyperflash from doing LED front signal bulbs, but the bulbs when used as the DRL would melt the bulb sockets when I had standard bulbs... the LEDs haven’t given me any trouble whatsoever since their installation (hyperflash aside)
Doesn't your car just use a thermal flasher relay for the turn signals? You should be able to replace it to eliminate the hyperflash. Didn't want to attract any unnecessary attention from cops so I swapped mine.
What's the light setup on the front of the Ion? Thought it just had the headlights and turn signals, with the headlights functioning as optional DRLs.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
