Old 08-11-2019, 06:14 PM   #96 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
What does hanging curtains for a stranger have to do with anything?!
My mistake. I assumed the threaded rod was for the stripped stud a few pages back. (About the time you were JB welding your exhaust manifold instead of replacing it.)
Post 90 seems to be about you searching hardware stores for a replacement crankshaft pulley bolt instead of just buying the correct Honda part.
BTW you cannot replace a flange bolt with a regular bolt and washer for anything with a critical torque. The friction is less for the bolt + washer so the bolt will be overtorqued if you use the torque specified for a flange head bolt
