Old 08-15-2019, 12:16 PM   #915 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I wish my fear was ripping my Prius to pieces due to acceleration. Really though, the problem isn't so much in acceleration, but to be able to safely come to a quick stop if need be.
What kind of loads would you be trying to haul? I mean the ABS and brakes on the Prius is pretty phenomenal. It does all the work for you. Just go brake check yourself on an empty road one night and press the pedal as hard and as fast as you can from say 60 mph. It really gets down. Pretty similar to the Mustang when it was on 235 mm tires and that car was also rated to tow 1000lb.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
