Old 08-15-2019, 01:09 PM   #23 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
My 2002 BMW had O2 sensors and my 2011 does as well. I can't find an O2 sensor for the 2007 Honda CB919 but a quick call to his local dealer could determine that. (I might not be looking in the correct place on the Parts fiche)
I did find an Air Control Valve. I'm not sure if that is for idle air control, or to inject fresh air into the exhaust to reduce NOx. Either way if it isn't working (Or someone removed it) the bike won't run right.
TurnNBurn - Is you bike a California model? If so it should have a EVAP canister. If someone removed it incorrectly that could also cause problems.
Name:	Air Injection Control Valve.jpg
