Old 08-21-2019, 11:55 AM   #24 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
It really depends on clutch material, line pressure and how much surface area there is for the fluid to push on.
Clutch material can vary quite a bit. You can buy "soft" clutches for manual transmissions or you can buy a ceramic clutch that you cannot slip and it grabs instantly(like in the big trucks).
More line pressure equals more clamping force. The same goes for fluid surface area. The more area there is for the fluid to clamp the clutch together, the more it will hold.
You can buy torque converters for pickups that have multi-disc clutches that can hold a ton of power.
A smaller tcc or smaller car will have less holding power, but they make less power to begin with.
If you want to find out for sure, use a tcc switch and give it the beans in each gear, watching for slippage.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following User Says Thank You to IsaacCarlson For This Useful Post:
EcoCivic (08-21-2019)
