Old 08-22-2019, 08:34 AM   #7 (permalink)
Daox
The alternator on the Mirage is rated for 85 amps. Will it ever really pump out that kind of amperage with a battery that is anywhere near charged? I have no idea. I will have to get an ammeter setup to test that.
While stumbling through my process of killing the alternator, I did discover a way to get the alternator to pump out a solid 15V. This is higher than it's normal output of 14.4V. A small boost, but it will help pump in more amps. I do plan on testing the higher voltage to see what difference it makes.
Perhaps with a small solar panel and the regen I will not have to plug in. That would be pretty cool. But one step at a time for now.
Thanks for the ideas guys!
