With the pre TDI I have a momentary switch right on the shift knob. Cuts power to the fuel injection pump. definitely helps brake when I come in too hot. Easy way to kill the engine without reaching, when I want to coast. The pre TDI's go to idle on decel not off. If trying to restart with the clutch always use high gear on a diesel. Or its hard on the clutch. On the little ladies van I want to put a momentary switch on the Idle Air Control (IAC), that thing really tics me off.
