Old 09-11-2008, 11:33 AM   #15 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Here are some more "facts" to help figure it out:
New Hampshire's Gasoline Vapor Recovery Program - Protecting the Air We Breathe
"eleven pounds of VOCs may be released for every 1,000 gallons of gasoline during fuel transfers. "
Assuming 6.5 lbs/gallon for gasoline, the volume of the vapor represents about 11/6500 of an equivalent volume of liquid gasoline. Or another way to look at it is the vapor density is 0.17% of the liquid density.
It shouldn't matter vapor wise if you put in 5 gallons in two fillups, or 10 gallons in one fillup, you are putting 0.17% VOC back into the pump (or into the air) in the form of vapor. The obvious difference between the two is the amount of weight you carry around.
