Old 08-28-2019, 10:59 AM   #15 (permalink)
aerohead
shouldn't
Originally Posted by modified metro View Post
If the variables at the bottom of the speadsheet is changed, shouldn't the CD and CRR numbers change also?
Since you're testing on a different day,the only way that you could isolate a difference,is to do back-to-back coastdowns,with and without the mods,so you'd always have a baseline reference from the same day/conditions to compare to.
You could have a dozen unaccounted for variables,any one of,which could affect your coastdown times.It would be impossible to sort it out.
modified metro (08-28-2019)
