Good point.
How are the tires wearing?
Brake drag is easy to diagnose at least and usually pretty easy to fix.
Good call.
There is some front brake rubbing noise at low speeds. There's also a sway bar end link (I think) that needs replaced.
I've never worked on brakes before, so should be fun!
Tire wear seems fine, but they're relatively newer tires. Previous owners installed them just a few thousand miles before I purchased it.
