Old 09-02-2019, 10:00 PM   #8 (permalink)
EcoCivic
Originally Posted by Gasoline Fumes View Post
I had non-resistor plugs and I made non-resistor wires for my carbureted 1984 Civic Wagon. Other than making lines on a TV from about 100 feet away, I didn't notice any difference. I also did not track my MPG with that car. Does a stronger spark make any difference if you're not having any misfires?
Interesting, thank you. And yes, a stronger spark can improve performance and efficiency, even if you don't have a misfire. The reason is because a larger, stronger spark will ignite more air and fuel at once, which means faster flame propagation. This is more important at higher RPMs where there isn't as much time for the air/fuel mix to combust, but yes it can make a difference.
