Old 09-04-2019, 10:24 AM   #13 (permalink)
Piotrsko
Originally Posted by EcoCivic View Post
Great point about the gap! I gapped the plugs to the OEM spec of .0044 inches. Should I have gapped it wider to get the maximum benefit?
They should be gapped bigger,55 thou, but it has been so long since I did spark ignited engines I forgot the rule of thumb. Maximum gap is a mix of various worst case scenerios that prevent effective fire (aka fouling).
Ideally, they should also be indexed, but you need either gaskets or many more plugs.
EcoCivic (09-04-2019)
