Old 09-05-2019, 03:30 PM   #13 (permalink)
oil pan 4
For get about hydrogen.
Yeah I added retract springs to my disk brakes on my leaf.
They cut down on brake drag, use 2 or 3 springs if needed.
If you have a thermostatic air intake good.
Install a wide band oxygen sensor and meter and get a edelbrock 4 barrel carb of the appropriate size for you engine.
Use the wide band 02 to tune the carb for a good idle, lean cruise and fuel dump at wide open throttle.
I was able to get my 1985 7.4L suburban up to 16 to 18 mpg on the highway.
