Originally Posted by EcoCivic
I didn’t realize that the spark will be a shorter duration. But even if it is, I don’t think it would matter much (if at all) because after the air fuel mix is ignited, it becomes the ignition source to propagate combustion, so I think it’s more important to ignite more air and fuel at once.
Great point about the gap! I gapped the plugs to the OEM spec of .0044 inches. Should I have gapped it wider to get the maximum benefit?
It does matter, because the air in the combustion chamber is moving. This is why new engines have multiple spark events under some conditions.
I would imagine a bigger gap would be beneficial if the spark can make it across. The resistor doesn't change the potential before the spark forms, so a bigger gap won't produce a spark as easily.
