Info correction....
before I read through all the posts, the original post needs some updating/correction. I might have made them before, but I haven't been on Ecomodder in some time, the CRX has been retired.
88-91 Civic DX LX / CRX
3.722 was 88 only, 89-91 was 3.889
All 1992-2000 trans have one of two speedo gears: EX/Si/HX use “big bore” black one and others use white one but outer diameter is the same.
Honda used white big bore (40mm) speedo gear in the 88-89 transmissions, but also a few have shown up in 96-00 EX transmissions, seems Honda was raiding the left over parts bin.
98-00 EX HB
Those didn't exist in USDM market, might be a CDM chassis/trans? Were they 35mm (small bore) like the 90-91 EX Sedan's or 40mm (big bore) like the 92-00 USDM? Quaife never got their info correct.
I haven't worked with 2001+ D series trans., so I cannot comment on those.
California98Civic, if you need more info, a PM should work and get to my email address. Thanks for the work!
-Mista Bone "D" tranny guru
PS: Those casting codes and 35mm vs. 40mm info, those were found out when I had 15-20 transmissions in the three seasons room at my old house 20+ years ago.
