Old 09-11-2019, 04:00 PM   #40 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
I only got it this spring. My utility trailer is only 5' wide, I think it would hurt more than help unless 8' wide or you could probably cut a section out of the middle to make it narrower. I also figured put it as close to the hitch as possible while still allowing turning and then skin the bottom. If it's not tall enough then build up a box to put it on, it would actually be perfect for sleds with the skis slid up underneath. You could also add hinged panels to the top and sides that form a kham back but move out of the way for loading.
The Following User Says Thank You to Hersbird For This Useful Post:
aerohead (09-14-2019)
