Old 09-12-2019, 11:18 PM   #15 (permalink)
cRiPpLe_rOoStEr
Originally Posted by royanddoreen View Post
might be a crazy thought, but can you match rpm by having two different o.d. size tires from front to back?
Makes me remind those Japanese and Korean cab-forward minitrucks with smaller rear wheels and a higher differential gear. But those were used in order to allow a lower boarding height, not to compensate for mismatching differential ratio in a 4WD version (which I have only seen on SRW and matching differential ratio). AFAIK the only 4WD applications with wheel sizes mismatching between the front and rear axle are agricultural machinery.
