Old 09-12-2019, 11:21 PM   #30 (permalink)
cRiPpLe_rOoStEr
Sounds too complicated trying to store thermal energy instead of converting it into chemical or electrical. Well, maybe a good alternative would be recovering exhaust heat, repurposing an old absorption fridge to serve as an air conditioner, and then if you use the moisture taken out of the interior of your vehicle as a source of water for supplemental injection you'd be able to go leaner and using that moisture to avoind knocks and keep the temperature under control.
