Rabbit is a good choice for wvo.
Where did you get the info about poor quality of 2 tank systems? You definitely have to assemble them properly, and i'd bet that some components are picky. If you want something really nice, just build one, they are not that complicated.
Honestly I CAN NOT see a single tank setup making it through an Illinois winter.
To pump the oil through a water filter you can use a 1" harbor freight water pump (2 in series if you don't want to heat it). Jeans should be sufficient alone . . .
2012 Tesla Model S P85
2013 Nissan LEAF SV totaled by now deceased intoxacated driver.
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
