Doomed
Have you ever considered getting rid of both those cars and getting something reliable?
As for the stripped holes did you clean the threads on the studs before trying to tighten them? It is important that both sets of threads be clean. You should be able to thread the correct size nut on them with your fingers. Did you test assemble things before installation?
