Old 09-17-2019, 01:18 PM   #37 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
I got the cargo area insulation and sound deadening project done and the interior back together. Made a decent difference in cab noise, which is nice.
I found an ideal aerodynamic positioning for a front mounted winch, it it called the cargo area. Using my hidden front hitch and an extension I can mount a cradle mounted winch on the front when needed, and take it back off to stow inside when not needed. It also works in the back receiver thanks to an extension cord.
MPG is definitely up after doing the work on the brakes. I have been driving without the kamm shell because I removed it to fix the leading edges that did not turn out well. I need to either find time for that or slap it back on for now.
ID:	26850   Click image for larger version
ID:	26851   Click image for larger version
ID:	26852   Click image for larger version
The Following 2 Users Say Thank You to aardvarcus For This Useful Post:
aerohead (11-20-2019), slowmover (09-25-2019)
