Old 09-19-2019, 07:27 AM   #9 (permalink)
RedDevil
90 day: 57.12 mpg (US)
You're trying to heat the wrong component in the combustion process.
The combustion process should run about a stoichiometric air-fuel ratio of 14.7 - 1 (mass related) so by heating the fuel you are just heating 7% of the mass involved, which will have very little effect.
If you heat the air instead you heat the other 93% involved - and it is way less risky.
I experimented a bit with heating intake air. It does have an effect: it makes the engine idle lower earlier and (anti intuitively) the engine heats up less fast, probably because the combustion process itself is running more efficiently. I may well have another try at the eWAI coming winter.
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
Daox (09-19-2019), Ecky (09-19-2019)
