Maybe start the negotiations at $4,500? Or even lower?
Just point out the lack of trained mechanics and how the car is 7 years old. Stuff will break and if the local stealership does not have a trained mechanic, getting it fixed right would be an issue.
But for that old of a car, it does not look bad. If he just commuted it, then probably lots of life left on the powertrain... but maybe not in the other things...
I would definitely give it a test drive and check the standard stuff.
