URabbit, do you know what your coolant temp is cruising on the highway? I don’t care what the gauge looks like, I’m looking for a digital number from a scanner / code reader / scangauge, or if there is a digital readout in a driver information center.
If you’re running slightly cooler than you should, there won’t be many symptoms. You would have reduced heater performance and fuel economy, but either of these could be minor enough a lot of people wouldn’t notice
