Originally Posted by SVOboy
Section 4: Modify your vehicle
Vehicle modifications are some of the most difficult and hardest to quantify changes you can make. Some of them are great, others might seem like more effort than they are worth, and some will be just too hard to do. Pick and choose.
3 - Increase tire pressure
This is one of the easiest ways to increase mileage. I currently have my 44 max psi tired inflated to 50 psi. This doesn't mean that you should do it, but it has been done by many people. When overinflating, inflate a bit at a time to test handling and feel before you settle somewhere comfortable. Be prepared for a bit rougher of a ride, but you will see the fuel economy increase!
There is also the possibility of running a solar car battery charger, though I haven't heard of anyone experimenting with this yet. Make sure to only remove the belt in case you need to reattach it at some point to deal with rain or darkness!
This article delivers great pieces of information. I am actually planning on increasing the mileage of my car. Got done several modifications but I was expecting more results after this.
_______________
Car News by Patti.
