Old 09-27-2019, 03:17 PM   #7139 (permalink)
oil pan 4
Something to consider.In order to get a report together for publishing,there's a cut-off date,after which no new information can be accepted.This has meant up to 24-months in the past,making the published data obsolete on the day it's released.
Also,the IPCC has a 'range' of outcomes,predicated upon percentages of probability.Unless,as you are doing,reading the entire manuscript,most will be unaware for instance,that there's a higher likelihood that the average global temperature increase will reach 11-degrees F(4-C) by 2100,than you'll be involved in a traffic accident,or your home catching fire.
If it's settled science then why does so much change from report to report?
aerohead (09-27-2019)
